You can manually set the reflection and refraction depths only for the glass material to something like 20-30. Did you try this and doesn’t that work for you?
The darkness of the bottom is the reflection of the refraction of that copper thingy. Try rendering without them, shouldn’t be that dark. Also, as stated, just up the reflection/refraction depth of your glass material not all of them by changing the override.
Also, the cutoff value is very high in the glass material. We often ran into problems with that, which is why in newer versions of V-Ray the default is now 0.001
Remake that shader, it’s ancient as the cutoff value shows.
Fog units scaling is off too, and it’s nearly an order of magnitude more reflective than it ought to be.
Also, why the diffuse component in a perfectly refractive object? It’s going to be calculated for nothing at all (at facing angles refraction overrules it, at grazing angles reflection does.).
If you could anyways post the scene reduced to minimum terms (one plane and glass which show the issue, along with the lights and textures needed), one could be more precise as to why overriding global depth seems to fix the issue (besides total internal reflection and low shader bounces, coupled with the high cutoff. Too far a shot.).
Rebuilt the shader from scratch, but didn’t really change the look of anything.
Got it rendering correctly by changing the reflec/refrac values of anything that is picked up in the reflection/refraction of the glass to 30 (so the glass itself, the wall mat, the shelf mat and the copper mat)
