Why is it that the glass material is not rendering transparent? I’m using the standard vray material without any adjustments. I placed sphere lights inside and when it begins to render you can see the light shining through the window but when it finishes processing the image the transparency disappears. Attached are images of what is happening. Is it a bug or a setting?
Had a similar question in the general forums maybe this will help?
From my understanding if your using the out of the box vray texture on a 2D face the fog density is infinite, which then blocks out the light coming through from the back and your reflection takes over.
I’ve attached the material file Konstantin attached for me also.
Simple_Glass_Tinted_01.zip (106 KB)
Thank you so much. Your glass worked perfectly.
If you are referring to the table. Change the fog color of the glass to pure white and try again. Or lower the fog distance of the glass material.
Hope that helps.
Best
Thank you - changing the color of the fog fixed the issue, but why is the v-ray stock material needs this in order to work properly? I’m frustrated it didn’t work out of the box.
What about fog distance, where is this adjusted?
I meant the Fog Multiplier, sorry
You could lower it to 0.001 for instance. Also make sure that your glass is modeled with the correct realworld thickness. Another thing could be reversed normals.
Best,
