Glitter shader
Hello!
I’m trying to create a shader that simulates glitter effects. In mental ray I would use a car paint material, but any idea how to get it in corona?
Some examples of the effect I’d like to get:
Thanks :smiley:
Try to use Spekle map or low scaled contrast smoke in reflection collor
Here is my idea that would probably require some refining. :wink:
glit-mat.zip (206 KB)
I thik it need bled sort of carpaint material with a glossy reflections on top.
Or it needs a castom specle bitmap (hand made)
My sugestion scene below.
2nd Try
T2.max (188 KB)
But it also definitely needs a bump map so that the flakes reflect light in different directions. This gives the “sparkling” effect.
Thanks to all!
What I’m doing is using the same map (is a custom map, like a speckle) for reflection color and glossiness. The bump advice was perfect, I’m getting closer to what I’m looking for!
Interesting idea with bump, got to remember that.
Here’s my attempt.
For such effects would be nice to have ability to disable bump mapping affects on diffuse shading, like it’s possible in Mental Ray.
Glitter.7z (244 KB)
possible with blend mtl :wink:
Very interesting. Will try to figure it myself, but shoud i fail i’ll cry for help ;]
I thought exactly the same when trying it.
A car paint flakes material isquite easy to create: all you need is 1. a material with a noisy normal map for getting this very small planar flakes pointing in all directions, receiving those sparkling highlights plus a second material layer for the clear paint coat over it. Not at work now, so can’t provide examples.
Corona scatter with very small pieces of geometry?. THE REAL DEAL!
