Glossy reflections in 1.45.70 painfully slow....
Glossy reflections bring my renders to a snails pace. Is this temporary with the 1.45.70 build, or will it be this way in 1.5 as well? Is there anything I can do to speed these up?
I’ve reduced the samples on the glossy material down to 4 and naturally that’s too grainey…if I leave it at the default 8, the grain is not too bad, but still visible but the render time is not acceptable at 8 samples…higher than 8 is out of the question..but needed to smooth the texture out.
Thanks for any advice,
Jeff
System specs: Dual Xeon 3.2 (1mb cache)
2 GB RAM
There were some problems with glossies that slow them down quite a lot compared to the previous versions; those will be fixed for the next builds; in any case a scene demonstrating the problem is always welcome, so that I can verify that the problems have been really resolved.
Make sure you set your max depth set to one or two.
Ahh, I forgot to adjust the max depth. I reduced it down to 2 and that helped a good bit. So now I’m using 6 for the samples and 2 for the depth, it’s a fair bit quicker (reasonable render times), but it still feels slower than the previous VRay version (when it comes to glossy reflections)
I can’t submit this scene, but I can deal with a 25 minute render now, instead of the 1:15 hour render one from earlier tonight. Once I get this project completed, I will run some tests and use a scene I can post (if I have problems).
Thanks for the info & tips guys.
Jeff
same here, about 30% slower.
but we switch to MR completly so no problem for us.
Hey peter008!
you switch to MR ? what are your opinion about the difference between MR and Vray ?
cheers
olivier
peter stated in another thread that he’s gone and wont be posting again. lets just everyone wave goodbye…
Yea, with MR its about 120% slower and thats with no bugs, right pete!
Makes since to me :shock:
Tony
My thread…my little bitty sweet innocent thread has been violated by the OT bandit. :wink:
