I have a scene, no matter how I set it it still took 4-5hours to render a 2500px image. I have tried set it to:
Min:1
Max:24
Noise:0.01
(8h 24m render time)
Min: 1
Max:32
Noise: 0.05
(4h 40m to render time)
I change it to
Min:1
Max:64
Noise:0.05
(4h 32m to render time)
The scene have 80% glossy reflection material.
Attach image is Min:1, Max: 64, Noise: 0.05 setting samplerate element, it still rendering.
ps: forgot to mention, i am using batch render for this project
What’s the render time difference between V-Ray 6 and V-Ray 7? Since you’re using a lot of glossy shaders, try avoiding making them fully reflective or glossy, since this increases render times (i.e. make glossiness 0.95 and use a slightly less white color for reflections).
Joelaff
December 24, 2024, 5:38pm
3
Also, reduce the reflection depth to as low as you can get away with ~3-6 perhaps.
hermit.crab:
But using metalness reflection should be white color, right?
Will give a try, if not every time client asking for changes, it need 4 hours to render single, 3 views, it take 12 hours.
Just give it a try, both method mention above help, thank you very much for your help.
