Google's new Guetzli .jpg compression - how to use it?
Hi guys
I noticed that Google has made some pretty big improvements to .jpg image compression and made it open source: https://github.com/google/guetzli
Now, not being at all comfortable with this stuff I wonder if any of you guys know how to put that code to use?
I tried searching for some small program or upload service like tinyjpg.com, but found nothing.
You should count on using about 1 minute of CPU per 1 MPix of input image.
Pfff…
:- D Wat. Is that true ? So it’s like… 100 times slower than current algorithms ?
maybe they dont know what CPUs we have :smiley:
I don’t know what CPUs you guys have, but i think i have exactly that CPU :]
I am trying it and they were not lying about the processing times… 19 minutes and 4.5 GB ram later it is still running on 18MPix image…
Could you upload processed JPEG when it’s finished. And original if possible. Very curious to see the difference :]
already deleted them :confused: but you can try it yourself :wink:
Pfff… :]
Ouch! Think I’ll give up on that one then.
Can I ask what you guys normally do to compress large images for web? Normally I do it manually through the “save for web” in PS or if I have a bunch, I drag 'n drop to tinyjpg.com
Not getting a satisfying results on this set of images though. I’m on like 0.5mb for a 2k jpg image for a full screen landingpage. Curious if any one is using some other compression method available?
I buy bigger web server from time to time… there is about 25GB of user-uploaded images on Corona forum currently :wink:
hehe ouch! Server size isn’t the issue in this case though. It’s to keep the site loading times at a minimum :smiley:
