I am trying to get a floating ball of liquid, which then I want to burst which I want to see if I can do with a Maya fluid as a field (if this is possible).
I have also the problem of the liquid disappearing.
Okay, so for now you can workaround the issue by bursting the liquid with something other than the expanding sphere - try particles. The expanding sphere does not create the right velocities you need.
The expending sphere was just to remove it from interacting with the liquid. I need it to create the liquid on the first 2 frames.
I will burst the liquid with fields.
Also is it possible to use Maya fluid as a field on my Phoenix sim? I tried but that didn’t work.
I am still having my gravity issue and also the fluid shrinks until it disappears.
I was using the sphere to keep the shape at the beginning, then I wanted the sphere to get out of the way in order to have the liquid bursting.
Is there a way to key frame the interaction with the sphere (container) to gradually be off? Then I can animated the burst.
When I test my scene with the sphere excluded, my liquid doesn’t keep a spherical shape, it morphs into a squarish shape. (see attachment)
Would you be able to provide a sample scene with a spherical liquid floating in the air?
The wobbling is an effect of the surface tension, you may decrease it or completely zero it and the shape will be kept forever.
No way to gradually decrease the interaction though. We’ll see if we can make the sphere emit the correct velocities for one of the next nightly builds, but instead you can try to blast the liquid with and expanding sphere of particles instead - you have to attach them to a new Phoenix source and set it to fire/smoke mode, turn off temperature and smoke and set a strong discharge of several hundred, this should do the trick
Thanks for the surface tension trick.
I manage to get the effect with my container in a layer which I animated the visibility. Just before the container disappears, I have a PheonixTurbulence kicking in.
Now I need to play with the turbulence and the grid size.
Is the surface tension the reason for the liquid to disappear (in general, not specific to this sim)?
Also is there a way to use Maya fluid as a filed?
Nope, the surface tension just tries to keep the blob of liquid together, but the disappearing can be corrected by using higher SPF and higher cons. quality (as I see you already do), and I think you should try unchecking the ‘uniform density’ box - for liquids it’s better to use non-uniform density. If this doesn’t help, try with forward transfer advection.
About the maya fluid as a field, I don’t think so…
I seee, so then create a geometry over the area where you want the liquid to disappear, exclude it from interacting with the simulator, create a source in fire/smoke mode and put it in brush mode, set the temperature channel to 0 (this will be the final value towards which the liquid quantity will change / temperature is the same channel as liquid in liquid more) and set the discharge to a very small number - the smaller it is, the more slowly the liquid will disappear.
Alright, so with tomorrow’s nightly build not only translating and rotation bodies will affect the fluid, but scaling bodies as well.
You will need to create another source in fire/smoke more and emit only velocity (otherwise in liquid mode it will obligatory emit liquid as well, and we don’t want that). Set the source in brush mode, emit from the expanding sphere and exclude the sphere from interacting with the simulator, otherwise the brush mode won’t be able to kick in. Make sure the surface tension is turned off, otherwise the liquid will not blow up in small pieces, but in big ugly chinks instead. Un-check uniform density too, to make the liquid more liquid-like. You can control the effect of the expanding sphere by the velocity multiplier of the source, for example this is with a multiplier of 10 (also, reduced resolution, conservation quality and steps per frame):
