Guide for budget 32thread render node build / 2xXeon E5 2670v1 C2 sub 900 euro
Is it me, or the prices of E5-2670 has risen drastically in the EU? It’s over 100 eu per piece at the moment.
Haven’t followed 2670, but the 2680 I found have gone up from around 80 to around 110euro.
finally after some time i manage to build my WS base on your “tut” :smiley: main question now is should i use it as main pc, or as a render node, i have “old” pc i7 4790K 32GB ram??
2680 or 2689 - goog CPU and price!!
What do you thing about this:
Asus Z9PE-D8 WS + 2x E5-2690/Cinebench R15 2150 points/ + 8x8 DDR3 ECC REG 1600 - price 990 Euros
Asus Z10-PE-D16 WS + 2x E5-2683V3 ES /Cinebench R15 2900 points/ + 8x8GB DDR4 ECC REG 2133 - price 1600 Euros
Asus Z10-PE-D16 WS + 2x E5-2683V3 /Cinebench R15 3200 points/ + 8x8GB DDR4 ECC REG 2133 - price 1830 Euros
Quadro K5000+2xSSD+3xHDDs
PSU Corsair RM1000i or HX1200i /2 more graphics cards for rendering in future, maybe/
CASE Nanoxia Deep Silence 6, Rev. B /need more space for hdds in aluminium boxes/
If you have money, always go for newer solution. And for workstation, avoid ES mostly as they have very low turbo bins (mostly just single turbo for all-cores). There are exceptions of course.
In your case, 3rd option.
Hi Juraj,
following your guide I’ve built a workstation with 2 x Xeon 2670, with Noctua coolers.
Mainboard is an Asus Z9PE-D8: when I power the system everything seems ok, but Q-CODE Led of the mainboard is turned off, and the system doesn’t boot.
I tried to reinstall cpu and coolers, ram and power cables, but no solution. The PSU is a Coolemaster Silent Pro 1000W. Mainboard is powered by 1 x 24 pin and 2 x 8 pin power connectors.
Any suggestion?
Thanks in advance!
So when you press start, nothing happens ? The Q-Code is off and doesn’t write anything ? Do the fans spin ?
Sounds like PSU isn’t doing anything but maybe I read it wrong. I had lot of various board issues over the years but every time the q-code would at least indicate towards the issue.
The board receives power… fans are working and also video cards and hdd… but Q-CODE is off… and no signal is sent to monitor…
PSU seems to work well… I made a test with one CPU only, but system runs on and off continuosly…
Today I’ve tried a new board from Lenovo C30 workstation… but seems PSU can’t power the system… Mainboard turns on only for a second…
I’ve a CoolerMaster Silent Pro 1000w… can it be the problem?
Everything is possible. To be sure use power meter and measure the unit’s output. It is common practice :wink:
