NEw workstation Xeon E5-2687W
Hi everyone,
We are looking for new Workstations hardware to replace our I7-2600k Pcs.
We hesitate between 3930K Oc workstation or a Big dual Xeon 2687W.
For sure It is a big price difference, but what about Vray performance??
Our main concern Is the ability to render many Render region test, as we debug our scene.
Anyone With numbers ? bench?
thanks !
If you use a lot of proxies in your scenes, you will need an updated build of V-Ray - we did some optimizations for good performance on many-core machines.
Good to Know, thanks for the “tip”.
Do you have any benchmark or rendering time comparisons as a Dual Xeon E5 system Versus I7 3960k PC?
Can’t find anything over Internet, only Mental Ray, or Vue test.
thanks.
I’m considering a similar xeon based machine to replace my ageing macpro. For me stability is very important, as is the ability to do quick test renders (and region renders).
OC is the way to go in either case. It will render respond and be a lot more snappier at 4.5 ghz than at 3.2 ghz.
maybe I had (2) bad experiences with my i7 overclocked machines, but for my main workstation I’ll be steering well clear of overclocking. Both my i7-980x slaves crash quite often (once or twice a week) whereas I’m not aware of my macpro having had a single hardware-caused crash in over 4 years. Thats the kind of reliability I want in my main machine :slight_smile:
besides, I reckon 2x e5-2687w xeons will be snappy enough for my needs!
Heya
Uhh really? Thats very bad ! Now Im sure you did it but did you run prime95 for 48 hors and log in all temperatures/voltages and checked for spikes and so on to make sure it run stable? As well as had max if 70c?
2x E5-2687 Will still be slower than OC in single threaded tasks which there are A LOT in max/maya atm… for the price of that CPU u can have 2 workstations and DBR them together which would give you more render performance than e5-2687w I gues… not that I’m pushing any1 todo it… just chattin…chattin…
NN :slight_smile:
Maybe reading this will help a bit:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?69539-Xeon-E5-2600-vs-i7-SB-IVB-OC
Cheers~
I plan to buy a 2x E5-2687w system too. At single CPU usage the turbo mode will bring the task to 3.8GHz, not so bad. I looked at the Maxwell and the Cinebench charts and some reviews at the www. The 2x2687w should bring 25 CB points, an overclocked 3930k could bring around 11 points.
I don’t want to have to much machines here. My current 5 machines has approx. 20 CB points. If I would upgrade the machines, I would lost the old CPU power. After long time of CB point and money calculation I decided me for the Xeon. So I will get all together 45 CB points.
Important for me is too, that I’m a Vray for Rhino user and DR isn’t so good for render animations. Much power in the main machine will help me a lot.
Next thought - I could buy additional 3939k for my current little farm, but the power usage and the noise will increase. Also I think, the Xeon will stay a good working machine for the next years and if the CPU power is much cheaper, than I will upgrade the slaves.
The price for the Xeon will be around 4800,- €, for this I could buy four or five 3930k with 44..55 points. Not so much more points and the power ist splitted over the network, the next CPU upgrade would be less effective.
Since the 2687w can’t be overclocked I will try to minimize the power usage by a lower CPU voltage. So I hope to get a very quiet system.
Here a good CB comparsion:
I recently bought a new render-node. dual E5-2630 - Supermicro MB - 32GB Ram
Cinebench 11.5 :14,81 (2xE5-2687 = 25,29)
PassMark = 19,90
proc. price 650€ x 2 = 1300€. think is a good price vs perfomance result… since a don’t like to overclock my pc’s
sure.. if somebody wants a single powerful workstation… nothing is better than a 2x2687
Nop that is not really true…
U get more power from
EVGA SR 2 with 2x 6 core xeons OC to 4.6ghz… nothing beat it till today. :slight_smile:
Good to know - what are the CB points and which CPU is used?
I’ve just built a couple of workstations running the Xeon E5-2670 w/ 64GB Ram, 256 GB SSD, etc. We are extremely happy with the stability and performance for the money. I also have a couple of the latest iCore7 machines also, but they are just not in the same category of performance in our day to day usage.
Many of the overclocked machines that we have, still exhibit stability problems even after watercooling. They just can’t run for weeks at full tilt without crashing at least once, requiring some type of intervention.
I’m not saying that you can’t get a decent speed increase with an overclocked machine, it just takes WAY too much time and effort to get it running reliably. I need to know that it is still going to be rendering on Monday after a crazy long weekend of rendering. It’s to a point now, it’s just not worth my time / effort to keep it reliable when I need to be in production, and not constantly messing with memory / voltage tweaks.
YMMV. :wink:
I guess it depends on the system. Some setup are just not good at it. My old 920 machine at home has been running rock solid at 4ghz since the day I bought it.
Good to know. What made you go for the e5-2670? less power hungry than the 2687w?
A lot of people overclock them too much too quick tbh. With OC you need to bake your cpu. U cant just buy it and put at 4.5 within hour of purchase. It has to run at it stock clock for few weeks to bake properly, then slowly up all stuff and it will be fine…
I’m no stranger to overclocking and understand proper ramp up…slowly working up to a higher speed. Our machines are far from simple and I would attribute most of the problems to needing high amounts of RAM, allowing for a much higher instability rate. Again this is just our experience here, if you want to overclock by all means squeeze all that performance out of that chip. :wink:
@peterguthrie: I chose those due to diminishing returns on the cost / performance. We found that by stepping down I put the saved money towards a higher end Quadro card. (We work with LOTS of engineering data and Body Objects in Max, our GTX 680s were unusable in wireframe mode. The Quadro gives us 10x the performance in those scenes. So it was necessary to maintain productivity.)
@duke2: I would agree 100%. Different machines each brought different issues. Again, I think that running a minimum of 32GB Ram is causing most of our problems. In the end, I would rather take that troubleshooting time and turn it into productivity even if I lose that 15% performance bump.
I too am plaining an aditional workstation. Initally I looked at e5-4617 because I want to get a CPU with factory setting of about 3Ghz, don’t want to overclock…and then I saw it’s one of the rare ones with no hyper-threading :frowning: I also wanted this one because its newer sandbridge core than 2670w, right?.
So, any suggestions?
about 3Ghz, 6-8 cores, I have a price range but they are MUCH different in Croatia - more expensive…so I don’t think that would help you. Also, any suggestions on where to get these xeons in Europe? Like some central European dealership.
thanks
Mmm.. I had very bad experience with Xeon. It was a 5445 if I remember correctly.
No possibility to OC and, also FBDIMM memory was expensive and VEEEERY HOOT!!!
In the supermicro board, after some minutes of work (internet, excel) without a fan over the RAM, Windows crashed!!! Really!
I had to put a 12cm fan aver the RAM area, or I could cook a pizza. Also the Southbridge was very hot.
Without my fan, the workstation was very unstable. After some 3 years, the expensive MB, recognized only 2 bank or RAM.
Good service Supermicro, sent me a new MB free. After this experience, I stop with an expensive Dual Xeon :slight_smile:
We are not a big company, and with some 970 in OC we are ok. First, OC about 3.9 is good for this processor. Over, you can have crash an no so increase peformance. I see some 4.3 Ghz version.
but i think they are unstable and very ot. There are no difference for 50 min vs 43 min, in my opinion.
Temperature 62°C under full render. The important is to have low RAM setting.
Also a 970 WS is good for resale. No one wants an old, heavy dual Xeon! But you can sell easily some good 970 Desktop PC with 24 GB RAM.
Single thread is much faster with 4.5 GHZ desktop CPU than 3.0 Xeon. GHz/price is in favour on powerful OC desktop CPU.
About the preview, ok, it’s better a dual Xeon =) With the same price of one Xeon, you can buy one good single CPU PC + one good node.
You have much more flexibility with two PC. I have the same opinion for a little renderfarm (5-8 nodes)
