Hello, I m testing ornatrix hair and i ofc im getting some flickering in my beauty.
I dont have a perfect simulation and my geometry is bouncing a bit, but the thing is that i see flickering in my lighting pass. I was expecting only in my gi pass. In my reflection/spec passes i do not have flickering.
I dont know if its a material issue so im attaching the settings as well.
I rendered with RT gpu with not very high settings, my lc was 1024 but idk if that was the issue here. The only other thing i did, i checked lock noise pattern and changed filter to area with 1.5. Rest default
I let it render 1:30 min per frame with 2 x 980ti to see what i get. The image was clearing up well so i let it there.
Here is the passes in my dropbox, download em for better quality:
beauty: Dropbox - Error - Simplify your life
lighting: Dropbox - Error - Simplify your life
refle: Dropbox
specular: Dropbox - Error - Simplify your life
I dont attach gi, cause no need is obviously similar to lighting and the most flicker is logical to come from there.
Thank u very much!
Thanos
