hair/fur solutions
What are you guys using for hair/fur renders these days?
Im after a solution that works efficiently and can handle dynamics.
Hi
I’ve used max hair and fur after some headaches and got it to do what I need.
I made 1m tall grass blowing in the wind over a 100m X 100m plane (about 500 000 different grass blades in the wind. Works nice with wind but I foresee trouble when moving objects through the grass. In my case it was fine as it is only bushes. I have some soldiers running around but from a distance you can’t notice the grass is going through them…
im having major problems trying to get wind to work with max’s hair/fur.
I have precalculated the dynamics but for some reason it doesnt render with dynamics.
hmmm I had 2 different winds effecting my max hair and fur at the same time and it worked great. I did however notice that the viewport preview is not the same as the render ie if you happy with the viewport playback then double the wind settings, recalc dynamics and render.
and what renderer were you running this through?
Vray? If so in buffer / geometry mode?
Unfortunately our R&D is leaning towards the fact that Max hair and fur is not stable or reliable for complex character animations, (i.e. a character with around 10 hair and fur sections, with around 5000 - 15000 hair strands per section) and Vray can only really support Geometry mode which doesn’t produce the nicest results (hair looks like straw, rather than Heather Locklier). Max 2009.
Vlado is that right? I think we did get Vray to render in buffer mode at one point?
I would love to know what people use for Hair and Fur solutions, which are not for Arch Vis work?
Unfortunately this seems to be one of the few cases (well the only case) where we have to switch renderers…
I rendered in vray in buffer mode with my grass being about 1m tall with 5 segments. It took me about 3 weeks of headaches to get it to work nicely. I did have to change the lighting settings in hair fur render settings otherwise I got random black grasses flickering all over the place. If there was another solution I would use it, but at the time I did not have budget for hairtrix. Also I’m very reluctant to buy yet another plugin especially one with so little information.
As far as I know hair renders fine in buffer mode, but it will not work with GI or V-Ray lights (only standard lights with e.g. shadow maps). Other than that, the built-in hair has its own problems, regardless of renderer.
yeah your not wrong!
And of course when combined with Shadow maps and standard lights, we’ve experienced flickering all over the place…
would love to know about any development on Vray Fur for Vray-2?
There are some possibilities for development in this regard, but it is too early to know for sure yet.
