Hair&Fur Velocity Channel
Hi Guys,
i have a strange problem or something i did wrong.
we are testing at the moment the Hair&Fur Support in max2010 with VraySp3a.
so far all is wonderful!
We like to render with velocity to do the MB in Post.so if i turn on the elements they seams to be not correct.please have a look at the pic.
simple setup,sphere with roate and moving up and down animation, precalculated hair dynamics, moving camera arround the sphere
any idea?
thanks!
did you render this with DR?
I know it seams to be a DR error, but there is NO DR. they render per Core different results (quadcore CPU).
i tested an sequenz of 50 frames (via backburner) and there all is fine, but for a single frame there is still this error.
here is the result of the 50 frames render, little comp and mblur in comp via velocity.
www.3deutig.com/download/hairball_v001.mov
c u
Jens
