All HDRI Background look like a cube
Also when putting texture at a large scale (for instance 4m x 6m) it is not rendered properly
I’m using the latest version of Enscapefor Sketchup V3.2.0 - preview.1-+51837 - And the Graphic card is a Radeon Vega Pro 48
Hey @Architure , thanks a lot for the report.
I’m afraid I cannot reproduce these problems on my machine at all with either the preview or the latest release. Just to make sure, do you also experience the HDR problem with this file here? Have you also made sure that your GPU drivers are up to date? And finally, could you send me more screenshots of the texture problem itself?
Hi @Demian_Gutberlet
Thanks for the follow up
Now the background is blured. I’ve place a 4K HDR file you gave me as as skybox . Fyi DOF is set to 0
Driver is up to date
For now there is no other problem with the texture but I’ll send it as soon I get one
Would it be a problem on my side?
4000px wide image / 360 deg = 11.1 px per deg, that’s what’s probably behind your blurryness. Even a 16000px image will only be 44px per deg.
No I don’t think it’s the problem here.
I’ve been using 4k HDR image since V2. As far as I remember, the older version didn’t allow more than 4k. And I’ve never experienced blurry background.
Now it renders unblured but the square effect is back
@Architure , thanks for the reply and further screenshot - this really doesn’t look correct at all. Can you perhaps send us a Feedback report as well? Please definitely also make sure that you’re adding a link to this thread in the submission form before sending it. Let me know once you’ve done so as well gladly.
