HEEEEELP!!!
Does no one else get these issues?
EDIT: See max is stuck on 33 passes and corona says 178 ?? (everything is dead as this point)
max and corona seems to agree on where things are at until about 30 passes, then max freezes and the corona framebuffer keeps going! At this point any limitation of pass or time is totally ignored! the screenshot below had a 30min time limit on it.. AGAIN as I have been trying to yell out for more than a week, if I stop it manually max crashes. Either way nothing is saved.
Easiest way to test this is to setup a 25-30K wide by 15K high render and do a crop of about 700x700 px, and render the crop. This happens locally, using PT+HD, PT + PT, over network.. and DR. IT doesn’t matter what method is used..
EDIT2: And no, you did read correctly… 30K by 15K pixels.
HUGE problem! my deadline is looking seriously grim currently ![]()
