Help. Material Library not loading in Rhino 7 (Have tried Escape 3.2 and 3.3, was working last week)
Hi all. Please can someone advise.
This week the material library has stopped loading in rhino 7. (am using, windows 10, Rhino 7). Everything else works fine, but when I click the material library icon (“Import predefined materials Icon”) in Rhino it just freezes and I have to close the little window for it to carry on working.
The rhino script just gets stuck on:
Have tried uninstalling enscape and updating, nvidia drivers.
Ben
2022.06.20 14:05:08.539 +01:00 [1] | INFO | Start Enscape …
2022.06.20 14:05:08.961 +01:00 [RenderWindowHostThread] | INFO | Starting Enscape
2022.06.20 14:05:13.701 +01:00 [RenderWindowHostThread] | INFO | Enscape started - elapsed: 4739ms
2022.06.20 14:05:21.849 +01:00 [29] | WARN | API Error: BeginUpdateWorld: Invalid operation (No error)
2022.06.20 14:05:21.934 +01:00 [29] | WARN | API Error: EndUpdateWorld: Invalid operation (No error)
Command: EnscapeOpenMaterialLibraryCommand
Actually this is all the info if it helps:
Load Enscape.Rhino.Plugin …
2022.06.20 14:04:53.805 +01:00 [1] | INFO | Rhino plugin starting…
2022.06.20 14:04:53.809 +01:00 [1] | INFO | AppDomain: DefaultDomain
2022.06.20 14:04:53.809 +01:00 [1] | INFO | Enscape directory: C:\Users\benst\AppData\Local\Programs\Enscape
2022.06.20 14:04:53.810 +01:00 [1] | INFO | Enscape version: 3.3.1+75071
2022.06.20 14:04:53.814 +01:00 [1] | INFO | Renderer version: 3.3.0.1723-gc4d750e
2022.06.20 14:04:53.815 +01:00 [1] | INFO | Rhino version: Rhino 7 SR 0 (7.1.20299.23101)
2022.06.20 14:04:53.895 +01:00 [1] | DEBUG | Assembly Load: Enscape.Cad.Abstractions&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:53.900 +01:00 [1] | DEBUG | Assembly Load: Enscape.WebServices.DTOs, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:53.904 +01:00 [1] | DEBUG | Assembly Load: Enscape.SiteModels, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:53.980 +01:00 [1] | DEBUG | Assembly Load: Enscape.SiteModels&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:54.055 +01:00 [1] | DEBUG | Assembly Load: Enscape.RendererApi&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:54.060 +01:00 [1] | DEBUG | Assembly Load: System.ValueTuple, Version=4.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51
2022.06.20 14:04:54.061 +01:00 [1] | DEBUG | Assembly Load: Enscape.BimTrack.Integration, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:54.138 +01:00 [1] | DEBUG | Assembly Load: Enscape.BimTrack.Integration&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:54.175 +01:00 [1] | DEBUG | Assembly Load: Enscape.WebServices.Adapters, Version=0.0.22102.1510, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:54.248 +01:00 [1] | DEBUG | Assembly Load: Enscape.WebServices.Adapters&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:54.249 +01:00 [1] | DEBUG | Assembly Load: Enscape.Localization, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:54.251 +01:00 [1] | DEBUG | Assembly Load: Enscape.WebServices.Adapters.Core, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:54.323 +01:00 [1] | DEBUG | Assembly Load: Enscape.WebServices.Adapters.Core&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:54.326 +01:00 [1] | DEBUG | Assembly Load: Enscape.MaterialDeployment.Adapter, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:54.399 +01:00 [1] | DEBUG | Assembly Load: Enscape.MaterialDeployment.Adapter&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:54.401 +01:00 [1] | DEBUG | Assembly Load: Enscape.AssetDeployment.Adapter, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:54.471 +01:00 [1] | DEBUG | Assembly Load: Enscape.AssetDeployment.Adapter&, Version=1.0.0.0, Culture=neutral, PublicKeyToken=ab917a421742ccdd
2022.06.20 14:04:54.472 +01:00 [1] | DEBUG | Assembly Load: Enscape.WebServices.Core, Version=0.0.22102.1509, Culture=neutral, PublicKeyToken=null
2022.06.20 14:04:54.500 +01:00 [1] | DEBUG | Assembly Load: System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
2022.06.20 14:04:54.506 +01:00 [1] | DEBUG | Assembly Load: System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
2022.06.20 14:04:54.517 +01:00 [1] | INFO | GlobalLogLevel changed to Information
2022.06.20 14:04:57.661 +01:00 [1] | INFO | Rhino plugin started.
Command: _Open
Name of the file to open ( UpdatePromptUpdateBlocks=Yes Browse ): “C:\Users\benst\Able partners\Bill Webb - ABLE\04_PROJECTS\1021_Sook\CAD\Rhino\220607_Sook Rhino Model V2.3dm”
Successfully read file “C:\Users\benst\Able partners\Bill Webb - ABLE\04_PROJECTS\1021_Sook\CAD\Rhino\220607_Sook Rhino Model V2.3dm”
Creating meshes… Press Esc to cancel
Command: EnscapeStartCommand
Ok I fixed it. There were two versions of the Enscape tab open in rhino.
Solution.
Reset the Toolbars: In Rhino, type ToolBarReset
Then reinstall enscape and it the material editor works again!
