well i have this interior with some rectangular lights but this render on 800*600 took 40 min on a good machine !! and those light splotches are all around the place
Any one of you know how to avoid them whats the setting i need to increase or what??
and another question how can i create a “cube of light” im making a small traanslucent material with a rectangular light on it but its not working
Re: Help Please how can i avoid this splotches?
are you using DR?
nop and i have the Check sample visibility on
What version of VfS you are using? Do you have emissive material? Are you using real glass( with refraction layer) or faking glass (only a reflection layer with transparency)?
Still the first version, i have emisive materials on the withe surfaces and im using real glass
If you have small object with emissive material with a very high intensity, you could get these splotchiness. Make a test by reducing or disable the emissive material to see if you still getting the stain. You should use emissive material to give the illusion that you have a light source, but use a rectangular o omni lights to produce the illumination. Best
