Help with rendering
Hi
I try to achive a nice rendered picture of a aluminium profile cut out (see picture). And i need to have it with transparent background.
But if i render it just with lights its very hard to get it to look good, because the lights are not bouncing at something. If i make a backdrop the product looks better but i dont want the backdrop to show in the png file.. Can i make it transparent but still affect the environment,.?
You can do the following (Option 1):
  1. Navigate to the Environment settings
  2. Remove the Background texture and leave the color black
  3. Add a spherical HDR image to the Reflection, GI and Refraction slots (as an instance)
  4. Render
If you save the image now the background is going to be transparent.
Option 2:
  1. Remove all environment textures (use black color)
  2. Create a Dome light
  3. Add the spherical environment image in the dome
  4. In the Dome Options make the Dome Invisible
  5. Render
Both options are similar.
However with option 2 you’ll get direct light emission from the Dome instead of relying on pure GI for the indirect lighting.
Option 2 is better for objects using mostly diffuse materials.
If you’re mostly dealing with metallic reflections both options are identical.
Hope that helps,
Konstantin
As a note, “affect alpha” option in dome light settings should be uncheck as i know, to get png output..
Correct. @kenancakir ​ thank you for the remark.
