… If anyone can help… I just can’t get this figured !!
The DM is a black & white GIF (2 colours/ no AA)
The Map is in the material displacement slot at 100% as Bitmap with blurring at 0.01 (min) and filtering = none.
I just cannot seem to achieve a straight extrusion.
The VRayBmpFilter textmap should help you in that regard.
Try using that to load your bitmap in the displacer, rather than the standard Bitmap map.
Also, i’d use 2D displacement, rather than 3d…
Put the VRayBmpFilter map in the appropriate slot in the displacement modifier, and make sure “Filter Bitmap” it’s turned off.
Hi Lele, thanks, I tried your tips and I still seem to be going wrong… here I have done a test using a checker map and as you can see the extrusion is still tappered… I am guessing it can be done…?
the checkered map has a blur filter on itself.
If you turned that off (o.o1), and still it doesn’t work, make sure you render the map to a file, and use high enough samples in the 2d displacement mode (my tests led to good enough results on a plane with 1024 samples, unless i looked at it from too close a viewpoint.).
However, my personal opinion is that for such regular patterns, you’re MUCH better off editing the Poly object.
Add an Edit Poly modifier, make sure the “Preserve UVs” checkbox is selected, and just select the two opposed edges of your plane. A simple “connect” command will allow you to add as many segments as you wish between the two and then use the “chamfer” command on the newly created edges.
The last step would be to extrude the faces you just created, giving you a nice and sharp edge between the wood planks.
All in all it’s a 30 seconds job, and it saves you a lot of rendertime.
Use the diplacement feature afterwards on the wood, to give it SMALL credible bumps, even at high glancing angles…
Hmmmm… so it can be done … which version of Vray are you on Eric? This is done on 1.48.03… is there any chance I can test your scene on my machine?
That’s a good mini tutorial Lele, my modeling is all done in ADT, my Max modeling skills are basic so especially good to have you explain this - I will have a go.
yeah for something simple like those wood planks i would definitly just model in the detail like studioDIM said.. just a 30seconds or so and your done. PLus would render much faster than if you used displacement.
