Help with Vraydisplacment
Hi all i have one question about displacement:
I have made one handpainted Displacement map in photoshop 256 levels of gray saved as a bmp 24 bit.
my problem is this even if in my painting is smooth there seems to be a problem or sensivity in Vraydisplacement because he make a very small noise over the whole model wich should not be there.
i use 3d mapping have also tested 2d but no difference is there anyone that knows a way for reducing the noise, i will be the most happiest girl that stopped smoking three days ago ever!
Thx Linda
Can you post an image of the displacement map?
You can send us the scene, to get a closer look at it.
< nikki@choasgroup.com >
nikki Candelero
I am sorry i cant because this is for my work and it is strictly copyright material i wish but i cant show you :?
JUst one piece from the DM cropped, for understanding.
It might be something like the diagonal lines crossing over a grid mesh at very sharp angles - almost like the problems you get with antialiasing lines that are slightly off vertic or off horizontal. What does the mesh for the cushion look like? Maybe use a tesellated mesh in triangle mode with a high detail setting and turn down the subdivs in the vray displacement? You mightn’t be feeding enough detail into the vray displacement to get a good result?
Use a 16-bit file format or adjust the bitmap blur settings; the lines that you see are the stepping levels in the displacement bitmap.
Hi Vlado i made what you said i saved the DM in 16 bit tiff format and added some blur and now it looks more bad! am i missing something or what can be the problem?
i have tried to make a new painting but in 16 bit and now he works super no noise at all.
and now i must paint the whole DM from the beginning!!!
Is it so or is there another solution for this?
Try to convert to 16bit first and then apply a blur to the image, I haven’t tried it but that should work.
No gijis it didnt work so either. I have painted the the whole map from the beginning but anyway now i know for next time :slight_smile:
Linda
hopefully this means we will see new stuff from you soon hehe. havent seen much from you recently
Da_elf i wish i had time to make things to show you but at this time i have take a very big freelance work and i dont have time to make nothing except work :?
But i visit you once an a while with my problems hahahahaha…
most of your clients have you on an NDA so you cant post their work?
Sorry i am sure i will ask something stupid, but what do you mean with NDA?
I find this on google is this what you mean “non-disclosure agreement” if you mean this yes… i cant show anything to third part.
If possible, try doing your displacement maps in zbrush2 in the future. Once you get a grip on the quirky ui, you’ll want to do displacement all the time :wink:
Hi - I am having my first go at Vray displacement :smile: … can I ask another question? I have a black and white 8bit grey jpg DM - this is made from the diffuse map & is effectively black & white vertical strips. I was hoping to see the geometry stepping in and out with nice sharp angles (90degs) but I am getting softer trapezoidal shapes :?: The texture is for vertical timber wall made from 2 layers of planks… any clues would be great.
Cheers, Cameron
Hi… to help illustrate the problem here is a picture, Cheers.
If you havent done it already, turn down any blurring on the bitmap that you are using for the displacement in the material editor for starters.
Thanks Jo - that helped… still trying to find how to get the map to cause a straight forward extrusion of the surface?.. this is what I have now & my settings? Cheers
