If I disable the VFB and instead use Houdini render View, then Houdini locks up randomly when moving an object in the scene while the render is active.
In general this happen within 30 seconds, you just need to keep the fender active and try to move things around in the scene.
the reason I disable the VFB and prefer Houdini render is I only have one monitor so the VFB floating window is inconvenient.
