House on the corner - Two exteriors
Hi everyone this is our last job, and the first made with the new version of vray 1.48.
Hope you like.
Sketchup 7.1 Vray 1.48.89 Photoshop cs3
Ceiling in sight
Cidden ceilings
C & C are welcome.
Re: House on the corner - Two exteriors
Ricardo: main isue in the image for me is that the white is super white and burn and that makes it unrealistic image, the trees on the background looks very blur, I like first one architecture over the 2nd one cause looks more original.
hi…
i wouldn’t change the white… the part of the wooden beams under the roofs in the house of the left look extremely realistic… actually, all of the ledt part look terrific, with that sort of blueish tint…
i would try to improve the sky and yep, the rees at the bottom of the image do not work, but i had not even seen them.
what i do think you can do is add some dirt to the pylons :stuck_out_tongue:
Thanks for the comments!!!
Teo: the trees are blurred because the image back becomes more blurred because of the depth z, actually have to do and can not focus on an entire scene with the same clarity.
And if you look at the reality when you see a white surface directly illuminated by the sun, is burned, when we try to make renders no exposure in these parts but that does not match reality.
Omar: I did not understand what you say from the bottom of the picture, greetings.
How did you get that ilumination?? its what i’m looking for .. kinda please share the tip (: thanks
sorry, i missed a t… trees… from the bg. :stuck_out_tongue:
great render again
I’ll change car, other is good :wink:
Cesarrrock: The lighting is nothing special.
Camara physical, linear multiply with 2 in the gamma value.
And adjusting tones and colors in photoshop
Omar: ok! :wink:
