How can I change the background color ?
Might se a simple thing - but…
Jorgensen
Re: How can I change the background color ?
Option> Environment> Background
Simply can’t get it to work
Can anyone change the backgroundcolor to white, and show me how to ?
Jorgensen
Why not download the “latest_default.visopt” in the download section. I tried it with your model and it works just fine with clear background.
Its the physical camera…adjust that and you can get it to work.
One hint more please ;D
In the Color Mapping rollout there is an option called Affect Background which should be checked. Disable that and it should make setting the white background easier
Thanks. I didn’t help, but I then loaded one of the predefined setting and it worked ok.
Maybe it had something to do with the selected Primary / Seconday engines ?
jorgensen
hi vray dudes, ive been trying to put actual image bkgrnd in my scenes (at options/envmt) but only a plain color appears, how do i make it appear exactly as the image at my background? (without putting the image physically in su insert image)
