coreym
1
Hi
VfSU2.0/SU2013/Win7
I want to have a plain white background, but still have skylight/background to affect surfaces.
I figured this was essentially making the enviroment/background ‘invisible’ to camera.
Is there an easy way to do this?
I could use photoshop and alpha, but i was hoping to use imagery straight from VRay/SketchUp
Any help would be great
Cheers
Corey
Environment roll-out > Set “background” to white and put your sky map in the reflection slot instead.
/Jackson
If you save as a PNG, the file with have the background removed and transparent already, if you are looking to import a background image in Photoshop.
coreym
4
Hi Jackson - thanks for your tip…
I had a go, the background seems to be grey:
Is there something i missed?
coreym
5
Hi Matthew - Cheers for your reply
I was hoping to not go through photoshop and use imagery straight out of VRay/SU.
Corey
What color do you want it to be, white?
You have to uncheck Affect Background in your color mapping.
coreym
7
Thanks Matthew - that worked a treat!
