Hi, if I use c4d-hair I’m not able to render 3D-objects-types like square or instances - it is only flat. Is there any solution? I need c4d-hair because of dynamics - vray-hair is no option.
Cheers
Tobias
There is an option to generate real geometry in the C4D hair settings, there you can set the shape
Die you try this? In my case nothing happend or the " hair" was flat.
Yes I try that several time, this carpet was done using the C4D hair system: Small Modern Living - Common :: Gallery - Chaos Forum
I’ll show an example in the afternoon
Very nice - is it available anywhere? But you didn’t use instances for the hairtype, right? Attached you see a simple scene. On the right side you see the rendering with Cinema standardrenderer - everything ok. If I switch to vray it looks like on the left side. The cubeinstances are gone - it is just rendering the type “hair”. I’m working with cinema 4d 21, Vray 6.
Cheers
Hello @steilvorlage.de ,
Please note that there is a known issue (bug ID: VC4D-656) where the C4D Hair always renders in a Circle type. This is logged in our system and I will let you know once we have more information on the matter. Thanks.
Ok, sad
can you provide a workaround with mograph and dynamic splines … or something else?
Cheers
Hello @aleksandar.kasabov
Is this bug fixed? I’m getting the hair round instead of flat also.
Hello @RwVision ,
This issue has not yet been fixed. I have raised its priority and will let you know if we have any updates on the matter. Thank you.
You can still generate real geometry from C4D hair and get whatever shape you want
