Like daniel said you can get same effect with the self illumination option inside the vray material + a falloff map set to “shadow/light” and a small tweak with the curve.
In my example I used a vray blend material with vraymtl = base + vray light material as coat. But only because in the 3.00.08 version the self illumination parameter is bugged. You should be able to create the same effect without the need for a blend mat.
Nice results ralphr! I’m having fun experimenting with this material.. Not sure how to make this work without blend material and just a Vray Color map in the Self Illumination slot- I get that far but don’t know how to integrate the falloff map? Does the Vray Color go inside the Vray Falloff map?
I don’t have the scene in front of me right now but you should pick the colors you want to “blend” between inside the falloff map and place that inside the self-illumination slot. The rest of the material I think should have a blueish diffuse(depending on the look) and reflection parameter as needed. This should give you the same look without the need for a blend material. The only thing I remember why playing around without a blend material is that I got a little bit more noise inside my render and the same render settings. Probably because inside my light material I checked “direct light” which the self illumination doesn’t offer.
If needed I can post the scene or screenshots of the material settings later today or tomorrow because I’m not in front of my pc right now.
