When I click on the “New Posts”, I want to be able to see only the Vray for 3DSMax Forum.
I tried to change settings in advance search and saved but it is no help.
I find it distracting to see all other software forums. Is it possible to have this setting on the forum?
You can kinda do that by going to advanced search, switching to single content type, set “search in forums” to the ones you want, set “Find Posts” to “Last Visit” and “And newer”. You can also save these as search preference, tho that might interfer with normal searches.
It works *instead of* the “New posts” button. In any case, I agree that having the “New posts” button show everything is annoying. We are looking for ways to make it show only posts from the forums for which the user is actually registered.
Thorsten’s trick is working pretty well actually. I just use it instead of “new posts” and I think it does what is needed… still figuring it out but seems to do the job.
But If I may suggest. We should have either color or logo coding for each forum too. So when we open New post section each topic with different software will be differently tinted or there should be a logo of software used next to it. ( I prefer tint as its big and hard to miss…)
