Hi all, I wish to know what methode do you use for creating terrain with road (with slope).
Personally I use Glue plug-ins but I think that there is a better way to do that.
I made a little tutorial to explain how I made road on terrain :
THE TUTORIAL : http://pixarchi.free.fr/tutorial/road/road.avi
and the codec : http://pixarchi.free.fr/install/tscc.exe
Thank you for your comments!
Is there a plug for creating terrain with slope?
No plugin needed… create the slope (editable poly, or terrain tool, whatever). Then use shape merge to cut-out the road. Then you can level the polys on the road however you want. It’s just poly modeling… there’s no magic button to do it for you.
unfortunatelly!
a nice plugin to get that task of my back would be more than gr8 imho!
Thank you for yours comments, I find that it’s so dificul to model a large terrain with multiple roads… :roll:
Hope I’m not hyjacking too much, but has anyone noticed that in MAX 9, the Shapemerge tool doesn’t work correctly? I can’t get carve splines into meshes at all like I used to in MAX 8. I’ve noticed that the Probooleans are super finicky also. Anyhow, great tutorials and thank you for the time you took to post them for us.
shape merge does not work well on complex, high poly objects. you would be better off using the Boolean>Cut>Split routine. When used correctly, it will always work. Just make sure to Subdivide the objects before (if necessary) to avoid long skinny faces. You can optimize afterwards. Check out the Visualization Insider on CGA for a tutorial on creating sites.
http://cgarchitect.com/news/newsfeed.asp?nid=3658
Hi thank you for your link, I will try this!
Or you can use Gugila groundwiz (www.gugila.com). In this case I just drew the roadmap in photoshop and GroundWiz did the displacement via VRay.
