How to set bump map in BRDFVRayMtl
In BRDFVRayMtl, i set diffuse and opacity maps using the available functions. the same way, i would like to set bump map also, but there is no function to set the same in BRDFVRayMtl class.
can anyone suggest how to implement this?
Regards,
Gopi.
There is in V-Ray 5. But we haven’t released V-Ray 5 AppSDK yet. Do you want me to look for an alternative setup for V-Ray Next?
Thanks for your reply. Do you have any idea when version 5 will be released? Also, if you can find alternative, please provide, and if it helps, thats fine.
Regards,
Gopi.
Here’s an example from our 3D guys:
BRDFBump Base_Mtl@mtl_brdf_0_bump
{ base_brdf=Base_Mtl@mtl_brdf_0; bump_tex_mult=0.3; bump_tex=bump@tex_0; map_type=5; }
With V-Ray 5 you will be able to set bump that just like Diffuse and Opacity.
V-Ray 5 AppSDK will be released in approximately 3 months.
Thanks for your reply. Will give it a try.
Regards,
Gopi.
Hello Stan,
Any update on VRay 5 AppSDK?
Regards,
Gopi.
We’re planning to release it later this month.
Thanks Stan for quick reply.
