How to vary Texture (offset, ration,...) on an Object when applied to cloner
Hello!
As one can see in the picture, the floor in my scene is quite repetitive.
I heard that you can solve this by using the UVW Randomiser. Unfortunately I’m unable to find a good tutorial online, so I wanted to ask in the forum.
I don’t want to vary the stone texture, just the offset and rotation, so the floor looks more realistic.
Is there an easy way to do this? I’m new to cinema/corona and also don’t know how to use the node material editor…
Thank your all answers:)
-Paul
Ok I think I found a solution for it. So for people also having the same problem:
First select the material and go to “diffuse”
Then search in the options for the texture after “plugins”
from there: >“corona”>“UVW Randomiser”
When chosen, (still in diffuse) you can click the little texture Icon and change the offset, scale rotation, etc…
For me this worked fine, but if there is a better solution, feel free to comment;)
There’s also this: Corona for Cinema 4D
