UVW Randomizer, Randomize by UV Tile ?
Hi Team !
Hope you’re good.
Is it possible to randomize by UV tiles with the UVW randomizer or an other node ?
I can do that with the c4d variation node “polygon variation UV Tile”, i’m curious to know if it’s possible with corona node.
Rémi
yes you can, offset, rotation, scale etc, by various settings
You can only randomize position with the corona node, while with the variation shader you can randomize color, contrast gamma etc.
Each tile with a new color variation.
it shoud be nice if we randomise from cubic projection
Have you tried the Corona Multi Shader + UVW Randomizer combo?
You can find additional information regarding those shaders in our knowledge base.
I hope this helps.
Please keep us posted.
Kind regards.
