I have to make a rendering 30’000 x 30’000px in size. it’s a simple scene, but huge textures. one domelight, no sun, no other lights.
it’s not rendering at all!
I have tried everything, the only thing what’s working is rendering “stripes” over backburner, but it fails at the point of merging the stripes together.
If I want to render it as one image, vray fails at the point “…light manager” and then crash. what does the light manager do or what is it? is there a way to render such a huge image?
I have to solve the problems, because the customer (photographers) wants this size.
ps. I have to debug today… there is a forest and autograss in the scene, maybe that’s a problem.
If backburner renders out the strips but just won’t automatically stitch them together then you still have the strips and can manually put them together. I’ve had to do this several times, it’s time consuming but it works. You’re running out of memory so you could try reducing the map size of the objects in your scene, or buy more memory.
I know you said that you’ve tried everything, but just to make sure does that include rendering directly to a vrimg file?
That said, I recently had issues rendering a 20’000 pixel image & it turned out that Forest Pack Pro was the culprit. Swapped it out of instances & all was fine.
devin is right. If you use the MaxFramebuffer you need a lot of memory. Backburner use the Maxframebuffer to merge the strips together. You can also try to use the Vray Framebuffer (no Render to memory) maybe you have to save as .vrimg in case of the “Region - Problem” or you render e.g. 9 Blowup 10.000x10.000 pixel (Area to Render).
