I’m having a problem running V-Ray Spawner (CPU, no GPU) as a Windows service.
  • When started as a service, the Spawner itself stays active, but it repeatedly launches 3dsmax.exe -server. The process loads in the background, appears as Suspended in Task Manager, then shuts down. Spawner immediately restarts it, causing an endless loop.
  • I tried running the service under both Local System account and my Windows admin account (with password). The result is the same.
  • If I run Spawner in the system tray as Administrator (without the -service flag), I get the same looping issue.
  • The only case where it works is if I run vrayspawnerXXXX.exe by simply double-clicking it (normal mode, not as admin). In that case, 3ds Max loads minimized and stays alive, and DBR works normally.
  • However, running in system tray like this is not reliable, because Spawner sometimes crashes or stops automatically. For long-term stability, I need to run Spawner as a Windows service.
I tested with two environments, and both show the same behavior:
  • 3ds Max 2023.3.4 with V-Ray 6.1
  • 3ds Max 2025.3.2 with V-Ray 7.2
        License server: Chaos License Server 6.2.2 · Build 540106
Could anyone please advise me how to properly configure and stabilize V-Ray Spawner as a Windows service for CPU-only distributed rendering on workstations?
Note: I have few render server PC in my network. Some PC are working without any issue while running the vRay spawner as a service. Some are causing this same problem on each of them.
I have attached a screen capture video of the task manager of one of the servers.
Thank you for your cooperation.
This ticket includes a secure attachment. Use this link to access the attached files:
Screen capture - 37f3f47d8330460965bcab55824974eb - Gyazo
The tech support team are already working on your ticket.
I believe I am having the same issue was there a solution to this problem? Thank you for any kind of update!
Open up a ticket so that the technical support team can troubleshoot.
