Currently the All in One installer does not support keywords . It would be great to pass in the ENSCAPE Software Plugin to install. I.e. Revit, Sketchup, Rhino.
/RHINO=1 /REVIT=1 /SKETCHUP=0
Also it is not acknowledging the /SILENT and /Verysilent switches from INNOSETUP. Its all or nothing , you can manually select one and off, but not via passing keywords.
This is a must for deployments.
/VERYSILENT /SUPRESSMSGBOXES /SuppressFirstStepsWindow=1 /SuppressUpdateNotifications=1 /SuppressGraphicsDriverWarning=1
Do you need the options to select which Software Plugin to Install for silent installs? Revit, SketchUp, Rhino
system
November 3, 2017, 9:34am
2
Hello bimologist,
Fortunately, it’s already supported in 2.0.2.1844.
We published the manual for the installer program options here:
https://enscape3d.com/knowledgebase/installer-program-options/
As you can see, switches like /RHINO=0|1 , /REVIT=0|1 or /SKETCHUP=0|1 already work in exactly the way you suggested.
Let us know if you like it.
Can you please provide the Installer KEywords that are supported in the Preview AIO installer?
@Thomas_Willberger and @Simon_Weinberger at AU mentioned that this was implemented in the new installer based on my feedback from a past support request answered by @Demian_Gutberlet .
I was wondering what are all the parameters for the NEW installer
Especially to select which Enscape to install i.e. Revit / Rhino / SketchUp
i.e.
“%INSTALLDIR%\Autodesk\Revit Extensions\Enscape\Enscape-Setup.exe” /VERYSILENT /SUPRESSMSGBOXES /SuppressFirstStepsWindow=1 /SuppressUpdateNotifications=1 /SuppressGraphicsDriverWarning=1
set ECODE=%ERRORLEVEL%
Thanks I tried this . However there is a bug in the instructions
/CurrentUser Install for current user only (no privileges required)
/AllUsers Install for all users (privileges required) (This is the default)
This is a required parameter. if you do not pass /Allusers (thinking it is default) the software launches and results in an errorcode and does not install. `
i.e.
This will NOT install enscape
start “” /w %1 /S /SuppressFirstStepsWindow=1 /SuppressUpdateNotifications=1 /SuppressGraphicsDriverWarning=1 /SuppressRevitVersionWarning=1 /Rhino=1 /Sketchup=1 /Revit=0
You must pass /Allusers
start “” /w %1 /S /SuppressFirstStepsWindow=1 /SuppressUpdateNotifications=1 /SuppressGraphicsDriverWarning=1 /SuppressRevitVersionWarning=1 /Rhino=1 /Sketchup=1 /Revit=0 /Allusers
at least this is what I am seeing in my environment
Y:\software\Autodesk\Revit Extensions\Enscape>“Enscape-Setup-2.1.0.41-g551241f.exe” /S /SuppressFirstStepsWindow=1 /SuppressUpdateNotifications=1 /SuppressGraphicsDriverWarning=1 /SuppressRevitVersionWarning=1 /Rhino=1 /Sketchup=1 /Revit=1
Y:\software\Autodesk\Revit Extensions\Enscape>set ECODE=666660
Y:\software\Autodesk\Revit Extensions\Enscape>“Enscape-Setup-2.1.0.41-g551241f.exe” /S /SuppressFirstStepsWindow=1 /SuppressUpdateNotifications=1 /SuppressGraphicsDriverWarning=1 /SuppressRevitVersionWarning=1 /Rhino=1 /Sketchup=1 /Revit=1 /AllUsers
Y:\software\Autodesk\Revit Extensions\Enscape>set ECODE=0
also it would be a good idea to update the https://enscape3d.com/knowledgebase/install-enscape-silently/ KN to point to this article for the version 2.1 and above since it is now officially released
Also the new Uninstall.exe requires the same parameters as required /CurrentUsers and /Allusers
C:\Users\teamstation>if exist “C:\Program Files\Enscape\Uninstall.exe” start “”/
wait “C:\Program Files\Enscape\Uninstall.exe” /S /ALLusers
for older it is uninst000.exe /VERYSILENT or /SILENT
system
November 29, 2017, 2:02pm
8
Thank you for pointing this out. We’ve adapted the KB.
