Installing 1.5 on both max7 & max8 on the same machine?
At the moment I am using 1.5 on 3dsmax 8. I need to render some old scenes that need max 7 on the same machine. The problem I am having is that when I install V-Ray 1.5 into max 7 the installer sees the current V-Ray max 8 install and won’t install into max 7 without uninstalling the max 8 V-Ray first. I need to have V-Ray running with both versions of Max due to some plug-ins used in the older Max scenes that won’t work in my max 8 setup. I would think that I could copy the max 8 V-Ray files into max 7 directories but I’m not sure what files I need to copy and don’t want to mess things up.
Hope this makes sense…
Check out C:\Program Files\Chaos Group\V-Ray\3dsmax R8 for x86\uninstall\install.log
That will tell you what files were install and were. Just copy them to max7 :wink:
Thanks, DaForce!
Not a problem :slight_smile:
