Installing On CachyOS? Terminated With Signal: 11
I’ve just installed Linux for the first time on a second drive and am working on learning it. I managed to get Houdini installed and running, but when I try to run the V-Ray installer I get “linux app installer was terminated with signal 11”. I’ve been trying to figure out what this means via google but haven’t come up with much. Is the problem that the distro I chose does not support V-Ray?
Thank you!
As we officially support CentOS/RockyLinux - I’d rather not get into troubleshooting the installer right now.
I can suggest a simple alternative - grab one of the ZIP builds here: Download | My Chaos
Unpack it in some location of your choice.
Go inside the package folder
Copy the vray_for_houdini.json file
Paste it in the Houdini installation folder → packages
Open vray_for_houdini.json file
Change the INSTALL_ROOT to point to the location of the unpacked V-Ray build
V-Ray should now be loaded when you start Houdini.
Best regards!
That worked!! Thank you! I’ve still got a lot of Linux learning to do! :slight_smile:
