Is it possible to render instance lights outside of Solaris using the instance OBJ node and instancepoint based expressions? I get a bunch of errors when I try. I also tried point expression to pull in SOP data on a single light and got more errors so I’m guessing this is not possible either?
Sure, here’s an example using the instance attribute in a Geometry node. It’s a bit involved on the wrangle part for the preview but other than that - nothing complicated going on there. To note is the Object Properties on the Geometry node holding the lights - Cd and intensity are specified as forced attributes under the main tab - if you don’t do that, V-Ray will automatically filter them out to speed up the export and render. Link to Scene.
Might be a workflow we haven’t considered - could you please share that hip file?
Best regards!
edit: I didn’t realize Andrei has already replied Regardless, hopefully the scene helps!
