intensity esponential
hi,
can you explain color mapping-Intensity exponential?
When can I use it?..interiors…exteriors?
thanx
Fabrizio
Well, you can use Exponential color mapping when you generally want a more warm atmosphere in your image. But again, it depends on other settings also. :slight_smile:
thanx
Well, the “Intensity exponential” mode is very similar to HSV exponential in that it preserves the ratio between the red/green/blue components of colors; the difference is that it doesn’t do the RGB → HSV → RGB conversion (which may lose some precision) but produces the result directly.
