Interactive rendering
Currently only experimental feature in standalone version:
Just saw it on fb. Great. Does it support motion blur, dof, etc? Is it the same thing as standard non-interactive Corona Renderer, only updating on every viewport change?
It is 100% the same, I am not planning on doing some half-assed interactive/gpu/… version of Corona
Liking the look of it :smiley:
Very good news!
Hope to test it soon. If it’s the same it works also with proxies?
definitely. Everything is supported, although cached GI methods may not be as interactive as this path tracing
NICE JOB!
OMG this is just great to see !!! hope it will be good also for legacy build :s
Finally it’s here :smiley:
Thanks!!!
BR!
I wanted to test interactive renderer, but always crashing (both release an assert).
How do you run it ? maybe a specific syntax ?
Yes. As I’ve said, the output is 100% identical to regular rendering.
It is quite experimental feature, so you need to do this:
  1. export the scene from max via the export button
  2. locate the folder with export.conf/scn/mtl/obj + Corona-#####.conf on the disk
  3. copy all standalone binaries into it
  4. run the corona-xxxx.exe export.scn from that folder
I have made an export and found files :
export.conf
export.scn
export.mtl
export.obj
but can’t find “Corona-#####.conf” (???)
copied all files from “!CoronaStandalone - interactive” into the export folder
launched CoronaStandalone_Release.exe and obviously, crashed.
I need a little more help…
is some number. The file is named for example Config-46591.conf (sorry for the mistake).
Create a .bat file, put:
CoronaStandalone_Release.exe export.scn
into it and run it
ok i’ve found how to export, will test this
guys, i’ve checked “export scene only” but nothing happens, how do you export and where can i found the exported scene ?
export button is in the render settings panel.
Exported files, I found mine in :
C:\Users"username"\AppData\Local\Autodesk\3dsMax\2013 - 64bit\ENU\en-US\plugcfg\corona
Export can be a bit long (depend of your scene)
Tell me if you can run the interactive renderer, please, from my side, it allways crash.
If you have an export checkbox, then you have old version, grab the newest one on dropbox :wink:
Also if somebody is having problems, contact me on skype/gtalk and we can go through it to find what is causing the problems
What HW do you run??
i7 980X - 24 GB Ram
