Small simple animation test done with corona.
PT+PT 16
Post done in AE
Kitchen.flv (5.46 MB)
PT+PT 16
Post done in AE
very beautiful!
How much time did you render all sequence? is it enough 100 passes? did u make some denoise in postpro?
i rendered with three pcs, first pc took 40mins for 100passes second took 1h30mins and third 2h20mins.
Yes i did a slight denoise with Neat Video in AE.
it took 3days to render, i rendered at 100 passes so i can see how neat video will handle subtle noise and also to see just how flicker free pt+pt really is
Hello nehale
Could you describe the scene?
Video resolution =
calculated total frame =
rendering time of 1frame =
greats
Raf
Hi Raf
Video resolution = 1920x1080
calculated total frame = 100 frames
rendering time of 1frame = i rendered with three pcs, first pc took 40mins for 100passes second took 1h30mins and third 2h20mins.
Hi neahale
doing the math, that would be for 100frame:
the first part 40 min.
the second part 1h:30min.
the third part 2h:20min.
Total time to render scene 4h:30min. for 100frame on a aspect ratio 1920x1080
No i mean
the first pc 40 min. per frame
the second pc 1h:30min. per frame
the third pc 2h:20min. per frame
rendering was done through backburner and took 3days roughly (maybe shorter was done over night) with all three pc’s rendering to render all 100frames
look at the render stamp at the bottom
Hello nehale
..ahh ok!
However, it is still as high as the time to render the scene to 100 frame.
