Interior lighting - Tips and Tricks?
Hello fellow Enscape users.
We are currently designing a high end cars showroom. It is east oriented and despite the high 5m windows I get really dark renders the moment the sun passes 10-11 o`clock. Do you have any tips on the right settings for the interior revit lights, because I get no results what so ever . Thanks!
Did you try the different render qualities? Some times I got a better lighting if I used only high. Also I placed a lot of sphere/spot lights, more than hundred.
@archidoge are the interior lights too dark? I presume that a lot of daylight is in your showroom around 10-11 am and it smashes your interior lights.
You could:
  • lower the sun intensity in the “Atmosphere” tab of the Enscape settings
    or
  • increase the light intensity of your artificial lights in the material properties of Revit
Hello! I’ve written an article on how I dealt with color bleeding in interior scenes. I’ve seen this question being thrown around on different forums and wanted to try to share my workflow.
https://www.axoscape.com/2018/02/06/enscape-color-bleed-tweaks/
Hi Tony, could you try to compare the results in your model by just adjusting:
  • Increasing Render Quality to “Ultra” as Enscape performs more ray bounces in this quality level
  • Insert the “White Ground” or activate “White Background” to get more white rays overlaying the red ones
“Sure thing @Jonathan_Knoefel , I’ll give that a shot and reply back with my findings.”
I’ve tried to limit to only those 2 options and it does help with the color bleeding issue considerably, but I feel like there still some color bleeding occurring. Here’s a comparison between those 2 options and the results I ended up with at the end of the article.
“Ultra” & “White Ground”
Workflow Results
I’m thinking the ambient lighting & color temperature are the missing pieces to fully reduce the color bleeding
