[Interior] Living room
Hi guys, it’s been a long time since I post my last work. :slight_smile:
Here’s what I’ve come so far…
Any C&C Much appreciated thanks..
1. Sketchup Screenshots
2. The Render
Re: Living room
very nice render , i like your nice ilumination
Re: Living room
can you share your skp , juste to see your light setting et render setting and see your nice texture plz
thanks
Re: Living room
very, very nice. those courtains and lamp shades look terrific my friend.
Re: Living room
very good render nice floor, timber, lamp and fabric
But i think it could be improved.
A. straighten horizontal lines by post or with the lens shift option of vray
B. curtain is a bit overexposed bring back some details of the folds or make transparent with a visible background.
C. dark sofa material is a bit noisy use better texture or increase reflection subdivision.
good image keep posting
Re: Living room
Excellent lighting quality! Can you share your curtain settings? It looks really good.
to get the curtains less “blown-out” you could use the color corrections to bring back some details.
Re: Living room
:o :o :o wooooow nice render :wink:
Re: Living room
Thank you very much,
Im sorry but the file is too big frend, but the light setting is using an inverse square
Thanks pal, the curtain does look OB
Noted pal, very appreciate your CnC, the dark sofa is actually use a leather material, bad idea isnt it? I Thought so ;D Thanks for the comment
The curtain is using vray2side try to set for the best fit, for the Over Bright Curtain yeah I thought so too, Thanks for the comment pal
Thank youuu
