I am running a test, the scene is only lit via Vray sun, so there are dark areas. Below is the settings for each render. As you can see the brute force method is very noisy and the irradiance map method is very splotchy.
I consider the settings to be quite high for both methods. Where am I doing wrong? Both methods have produced less than satisfactory results. The brute force method although the best took 7 hours! If I bump up the subdivisions any higher I wont be seeing the final render any time soon.
PC Spec
Intel Core 2 Quad Q6600
4.00 GB RAM
Output size = 1600 x 1200 px
Lighting = Vray sun & Sky
Camera = Vray Physical Camera
Image A – Irradiance map method
Render Time = 1h 19m
Result = Splotchy in areas where there is little light
Adaptive DMC Sampler
Min subdivs = 1
Max Subdivs = 24
Clr thresh = 0.005
Image Sampler
Type = Adaptive DMC
Antialiasing filter = Mitchell-Netravali
Environment = Off
Colour Mapping
Type = Linear Multiply
Gamma = 2.2
Indirect Illumination
Primary Bounces = Irradiance map
Secondary Bounces = Light cache
Irradiance map
Min rate = -3
Max rate = 0
HSph subdivs = 50
Interp. Samples = 20
Clr thresh = 0.3
Nrm thresh = 0.1
Dist thresh = 0.1
Light cache
Subdivs = 1600
Sample size = 0.02
Scale = Screen
DMC Sampler
Adaptive amount = 1.0
Noise threshold = 0.005
Min samples = 8
Global subdivs multiplier = 1.0
Image B – Brute force method
Render Time = 7h 14m
Result = Lots of noise
Min subdivs = 1
Max Subdivs = 100
Clr thresh = 0.005
Image Sampler
Type = Adaptive DMC
Environment = Off
Colour Mapping
Gamma = 2.2
Primary Bounces = Brute Force
Brute Force
Subdivs = 16
Light cache
Subdivs = 1600
Sample size = 0.02
Scale = Screen
DMC Sampler
Min samples = 8
Also, there seems to be a bug, when I set the Adaptive DMC Sampler to a max subdivs higher than the default of 4, save and close the file. When I open the file the subdivs default back to 4. This happens with both of the above methods.
Has anyone experienced this before? All other settings are fine, and remain what I set them to.
I have also tried this on various other files and It has the same problem. It leads to think does it render at what I set it to, or does it render at 4?
