irradiance map and adaptive amount 1
ive had problems with blotchyness using the irradiance map and adaptive = 1.0 even using silly high hsph. subdivs.
according to this lovely page:
http://www.interstation3d.com/tutorials/vray\_dmc\_sampler/demistyfing\_dmc.html
it can only be fixed by dropping the adaptive amount or turning up the min subdivs very high, both of which affect a lot of other stuff.
any chance something could be tweaked to fix this? a seperate min-samples setting for the imap perhaps? or something internal that just..fixes it..? im -almost- getting very good clean renders in a reasonable time using a modified version of the universal method, using imap instead of BF for primary… however this blotchy issue is bugging the hell out of me.
You could try setting it to a slightly smaller value than 1.0 - f.e. 0.9 or something like that. Setting the adaptive amount to 1.0 may have other unexpected effects (f.e. if you use VRayDirt for an AO render element, you will get extremely noisy results).
I did consider separate parameters for the irradiance map at one point; I still have to decide if it justifies the additional complexity.
In any case, you can always compute the irradiance map with one set of parameters, save it, and switch to a different set for the final rendering.
thanks vlado :slight_smile:
