Interior
Hi. here’s my latest work. thank’s for your comments
Re: Interior
realistic like real life but not like the advertising-like photographs
some dof are high quality, some are not
lights too harsh
overall realistic real life human view is better for the client can judge what will it look like
since advertising photography tend to be not real, but look good
Re: Interior
Beautyful! :slight_smile: what version did you use? :slight_smile:
Re: Interior
wow!!! the master is back!! this guy produces some of the best work here!! awesome renders, so much attension to detail!! please share your settings!!
Re: Interior
OMG it’s a great image :o :o :o
Re: Interior
great renders!
Re: Interior
Very impressive. Would hope to reach that level some day soon. What version of VRAYare you using? How long did each image take apporx to render?
Re: Interior
Great renders, the modeling was done very neatly besides to its beauty.
All the materials in general are great, only in the first image you should have adjusted the texture position (of the tiles) to avoid this repetition.
Awesome work :wink:
Re: Interior
Wow :o :o :o :o :o :o… Really impressive work pal… congrats… i like it!!!
Re: Interior
Excellent renders!
Could you please share how you did the carpet and leather sofa’s though, i’ve spent 2 weeks on them and they look nothing like yours! thanks in advance
Re: Interior
thank’s all bro.
I use version 1.48.89 for this scene .
this is a setting that I use, but it depends on placing the lamp, the light in the scene … with this version has many new features that I have not had time to learn about it. however, it is actually better than the old version, really great!
(..materials of the leather sofa..)
http://www.mediafire.com/?cr59dim2bgkvaed
Re: Interior
thanks so much for sharing the leather! unfortuantely i can’t open it because i have 1.05.30 :frowning: can someone with the new version please post pictures of the leather settings if possible.
Could you also please share your secrets on the carpet of the last few pictures? how did you make it look so “fluffy”? and how did you make the edges look so natural and again, fluffy?
Re: Interior
Fantastic job! as usual.
Best
Re: Interior
mebo: I used displacement for the carpet( with the edges rounded)
render
displacement
leather
Re: Interior
great things
Re: Interior
would you please explain how exactly you managed the carpet… step by step please… because i can’t get the same (or even similar) result.
Re: Interior
Make a rectangle, subdivide the face by either using the subdivide tool (costs £££) or use the line tool and draw some lines across it. Then select everything and group it. then go inside the group and select everything (make sure the faces are the front faces by using the monochrome view). Then paint them with a random carpet texture from sketchup. Then go to the vray material editor and click on the carpet → maps → tick displacement → click on the m → change none to “noise” → change the size to a small number (0.01-0.001).
Go to vray options and make sure the displacement box has something like “edge length 4”, subdivisions “1000”. play around with all the settings.
good luck.
or you could do it this way http://forum.asgvis.com/index.php?Itemid=90&topic=5225
notes: for displacement to work all the rectangle + subdivisions must be selected and GROUPED
for it to work EVERY face must have the SAME material in the group, if you have more than one material in the group, displacement will not work.
Re: Interior
Trangan, thanks for sharing bro!
i really want to know where you get your models from, i had a look at those leather sofas and they are extremely detailed. Are they 3ds models? and where do you look for your models?
I really want a footstool like the one you use in your renders and made one myself in sketchup, but it doesn’t have the amount of detail as yours does. can you please tell me where you got it.
Thanks :slight_smile:
Re: Interior
can you share the model?
Re: Interior
Amazing renders. How long did it take you to create each one of these interiors ?
