Intersecting objects - Black spots
Hey.
I tried search the forum for similar threads.
I found some, but no one solving my problem.
My problem is as stated in the topic. I have planes scattered on a object. These planes also intersect the object leaving dark spots.
The main object has a fastsss2 material while the planes that is scattered has a vraymt material with a high transparency (refraction)
You can see the setup in these images.
The scattered planes have 100% refraction in this test renders just to show of the dark spots a little bit better. in the final render i hope to put the refraction to 50% or so just a get a nice “fury” look along the silhouette of the banana.
What i have tried with no luck so far is:
-Turning of shadows
-Set affect shadows under refraction on the plane material.
-Secondary rays bias (different values)
My goal:
I want to create some “fury” details on this banana. And i want these details to blend with the banana.
Specs:
Windows 7 x64
Vray 3.10.03
3Ds max 2015 SP3
-Mats
We will fix this, but for the moment you can try using one of the other modes for multiple scattering in vrayfastsss2 (prepass based, or object-based).
Ah ok, wasn’t aware that this was a limitation.
Thanks for the options, I will try them out.
Edited:
Ok so i tested it.
Prepass-based illumination map seems to solve the black spots. But the overal quality and look of the sss is significant worse then raytrace. But anything better then the splotches :slight_smile:
thanks for the tip!
Cheers
-Mats
Ok here are some results.
This first image is
VrayFastsss2 On both the banana and the flakes with prepass-based turned on in the shader. (rate 0)
Second image is VrayFastsss2 on both only now with raytraced under multiple scattering.
This third image is what i originaly planed to do. Vrayfastsss2 on the banana and Vraymt with high refractance on the flakes. (using prepass-based on the sss)
I am not sure what do go for, because i actually like the result from image one.
edit:
added a forth picture to see the banana without the scattered flakes.
Best regards
-Mats
woa.
i thought i was all in the clear, now i start seeing pink spots instead.
strange stuff.
the peel have fastsss2 with prepass-based ID1 the flakes on the peel has fastsss2 with prepass-based id1 so they blend.
the banana and the banana flakes has the same setup only id2 to blend. the outer skinlayer (the yellow) has a fastsss2 with raytrace.
i just post it here while i keep debugging in case some one knows a quick solution to this one.
cheers
-Mats
hmmmmm…
I saved, restarted max. and without doing anything, just instantly start a render again and it was solved.
now i’m more afraid what might happen when i submit this to the render farm. if it suddenly will start pinking out again.
anyways, restart works for now :smile:
-Mats
Ok, let me know if there are any issues.
