white splotches
This has been happening and the wierd thing is, it occcurs in a different place on different views. It seems to take a very long time when it hits the splotchy area
Tha mats have a bitmap in diffuse and bump and there’s a fresnel falloff. I’m running 1.5 rc2 and LC / LC for testing
Any ideas and a fix for it? Otherwise I’ll have to try and pshop it out :frowning:
I did have some as well, showing up pretty much at random.
The material it showed up on was a Glossy Reflective one, with Raytraced Reflections turned off.
Camera was a PhysCam, sun and sky were at 1.
Looks like some HDR sillyness to me…
And i PSd it out.
Lele
thanks Lele…hopefully some others here might chip in :cry:
Maybe use the new button in Renderdialog…
Ähh, Well, cant remember the exact name or place… use subpix…
subpixelmapping… ???
this solved our problems..
:roll:
Tom
tried that Tom…I think the geometry is iffy…off he goes to redo it
Re did the offending areas twice and stl checked it the last time with 0 errors and it still was doing the splotches.
I had an adea and I moved the sun. After a couple of different placements no more problem. Is this a possible sun bug?
any errors in the vraylog?
… I guess it could be a sun bug, but I doubt it, would have shown its face before now I would have thought
No errors at all mate. Once I get this thing out of my hair I’m going to email Vlado about it
Could you do me a fav (if at all possible)
delete all teh mesh apart from that wedge that causes that problem. and make sure it still cause the problem with the other mesh gone.. rar it up and send it to me to have a look.
You have too much free time :smile:
Maybe it’s because of LC ? Maybe sample size is too low/high ? Try PPT mode. Or turn clamp on.
If you move the sun, do the spots move as well? If yes, then these are simply highlights/reflections from the sun/sky.
:shock:
really doesnt look right tho.
And i would have thought that a brick material wouldnt have had any reflection on it.
Daforce:
It appears in different places depending on the camera view mate. I redid that particular mesh 3 times yesterday and it still happened.
Vlado:
If I move the sun the splotches move as well. At the moment I’ve move it to a position where it doesnt seem to apper in either of the camera views I posted. I have a low fresnel falloff on the brickwork so maybe I should remove it although the brick doesnt look as good without it?
cheers
Ah ok.. i just wanted to do some tests and try to solve it/figure it out.
I would say move the camera back to a position that exhibits the splotches then remove the falloff and see if its still there.
Vlado might be right, but it still doesnt look right to me.
Can you post the settings for your brick material? Also, if there is any bump there, try to reduce the amount or to disable it and see what happens.
Vlado,
Here are my settings
Since I moved the sun away I haven’t had the problem. I guess my bump is rather high but I need to be able to see it from a reasonable distance.
Well, since this is an issue that comes up quite often, I think it would be best if we add an option for the sun to not be visible in reflections.
Hello, sorry to bud in on your thread siliconbauhaus.
its been a while since ive done any 3D at all so im a little rusty. but now i have to start again with a brand new version of vray ( thanks for that Chaos, very solid DR ).
i have somewhat related problems, regarding specs/reflections from lights in the scene. no matter how much i try to squize the sampling of a given material the specular of a light comes out ‘wrong’ ie. not smooth on a glossy mat.
Below is a render done without maps. Im sure its something i am doing wrong as i am a bit rusty, but please tell me what :wink:
Actually the faucet(sp?) is prolly ok.
There is an unsharp mask apllied post .
dennis, please check this link (specifically the section on color mapping):
read the manual ehh…but isnt that like cheating?
ok seriously though if thats the case im just to stupid as it could have saved me a days work. And its even suggested in this thread…tsktsk.
thanks, off to test.
one question though, you say its the ‘unbiased’ way to have them ( sub/clamp) both off. I’ve tried insane sampling settings and the dots didnt dissaper, what will make them go away in a unbiased way?
ok test done while writing. I can see though that it did help a little, but not interly gone. Will upload pict in a moment
