Inverse Square
When I create a spot or point light and render, my interior scene with the light shining through the window renders black.
I crank up the multiplier from 30 to 5000. Still no hint of light in the scene. I switch from Inverse Square to Linear and nothing.
When I select my light in model space, the light properties jumps back to Inverse Square.
1) It appears as the decay settings are not sticking.
2) Why do I not get any light in the scene even using linear decay?
3) Linear and Rectangular light seem to work just fine.
Somewhere I thought Thomas mentioned an issue simular to this? Nothing was in the bug list for build 11 so I thought I would mention it.
Cheers,
Bill
Inverse Square
You must, if you have choosen linear, again click at the linear button. It’s a current interface with special not typical rhino usage. My last info, it will be changed.
Inverse Square
How do you even go about discovering this stuff Micha? You’re amazing, I think you are going to have to move to Baltimore to be part of the ASGvis team.
