IPR rendering - camera vertical shift alters?
Weird little issue.
When using the Vray Physical camera and ‘auto’ vertical shift - all renders fine. If I stop the render - then start it again in interactive mode so I can continue to work - the camera vertical shift changes and isn’t correct? is this a bug?
Yes, but it was hotfixed. Download and reinstall V-Ray to see if it makes any difference.
Thanks Aleksandar Hadzhiev I will try that - but I only downloaded Vray 5.1 around a week ago?
I will look at the dates on the download page - is it the car that each time a new version “hot fix” comes out I need to download and re-install?
