IR goes into endless loop recalculating geometry when started
Im pretty sure this is a similar issue as was discussed in this thread: https://forum.corona-renderer.com/ IR keeps recalculating geometry however, i’ll post the offending scene file in case it is useful to trying to optimize your IR code.
When i open the IR with this scene, it goes into an endless loop of “recalculating geometry”. Sometimes it will eventually resolve. Mostly, though, cinema locks up or completely crashes.
OSX 10.11.6
Cinema R19.053
Corona beta1
To reproduce, simply open the scene and start the IR
thanks!
travis
Priorities test_corona.c4d.zip (3.75 MB)
Well if that tension tag isn’t being used, try deleting that. Keep us posted :wink:
Here is a slightly simplified version. The setup doesn’t quite do what its supposed to this way, but the IPR still loops on startup.
Priorities test_corona2.c4d.zip (2.24 MB)
Still looks like the tension tag is the problem, if you run the IR and delete that tag it renders as it should. I think it will take some looking into.
Great! Good to know that! Thanks and keep up the good work. Loving Corona!!!
