IR stuck in Parding and Geometry
Till last night scene file was fine and IR and render was working fine. morning I added some objects and IR stuck in Parsing Scene and Preparing Geometry and repeating again and again, just back view. Render is working well.
Any idea how can I reset IR…?
Thanks.
Edited:
for now back for 3.5 and its working fine.
Hi, it happened also to me, till I found that was the XPresso tag on a parametric object. when unchecked the enable box, everything worked as usual
We had at least 1 more report like this where the issue was related to XPresso updating geometry properties. Unfortunately, we don’t have any proper solution to this. The workarounds would be editing the XPresso setup or removing it. We should be able to fix this in Corona 15.
Feel free to contact us at https://support.chaos.com/hc/en-us/requests/new with the problematic scene and then we could take a closer look at what exactly is causing the restarts.
Thanks but I am not using nay XPresso…!
I will check file again… see which object having issue.
In that case, feel free to contact us here https://support.chaos.com/hc/en-us/requests/new and we can inspect your scene.
Got it… “Atom Array” deleted it was fine…!
I hope you will check it.
Thanks.
in another scene IR was stuck with CV Outline.
have to find in every scene…!
If you could send us the problematic scenes at https://support.chaos.com/hc/en-us/requests/new , that would be great, since hopefully our developers would be able to fix it.
